Sony A100 & Lens + extras
kenallwine
DSLR-A100H A100 Camera Body and 18-75mm Zoom lens (SAL-1870).
Only asking $275.00
This includes:
-Camera Body
-Lens (18-70) [normal use]
-Neck Strap
-Battery
-Charger
-8GB memory card
-UV filter
-Software (Windows)
-Manual
-Instructional Video from Blue Crane.
This kit can easily be expanded using readily available Minolta AF Lenses. We have used this camera with great results and it is in perfect condition. You will love this camera as an entry level DSLR kit.
• Dimensions (Approx.) : (WHD) 5 1/4" x 3 3/4" x 2 7/8" (133 x 95 x 71 mm)
• Weight (Approx.) : 1 lb. 3 oz (545g) body, not including battery, lens and media
• LCD : 2.5" TFT (230k pixels) LCD with Clear Photo™ design
• Microphone : N/A
• Viewfinder : Optical: TTL, 0.83x, 95% coverage
• Imaging Device : 10.2 (effective) APS CCD Sensor; 23.6 x 15.8 mm; RGB primary color filter
• Megapixel : 10.2MP
• Battery Capacity : 7.2V, 1600 mAh; CIPA standard: approx. 750 pictures4
• Battery Type : NP-FM55 Lithium-ion rechargeable battery
• Flash Effective Range : GN12 at ISO 100 (39 feet/ 12 meters)
• Flash Mode(s) : Manual Pop-up: Auto, Fill-flash, Rear flash sync, Wireless off camera flash (with Flash HVL-F56AM, F36AM), Auto/On/Off/Rear Curtain/ Wireless
• Limited Warranty Term : 1 Year Parts & Labor
• Burst Mode : Up to 3FPS; Unlimited to capacity of media (JPEG L/M/S); Maximum 3 frames (RAW + JPEG); Maximum 6 frames (RAW)
• Color Mode(s) : Black & White, Standard, Vivid, Adobe RGB (Except for Adobe RGB, all other color modes use the sRGB color space)
• Exposure : Manual Exposure: Yes, w/EV indicator, Manual Exposure: Yes; Aperture/Shutter Priority, Manual, Program Shift: Yes, Command Dial
• Live View :
• Movie Mode(s) : N/A
• Red-Eye Reduction : On/Off (all modes)
• Removable Flash Media Compatibility : Tested to support up to 16GB media capacity; does not support Access Control security function
• Scene Mode(s) : Portrait, Landscape, Sunset, Night View/Night Portrait
• Self Timer : Yes (10 seconds, 2 seconds, Off)
• White Balance : Auto plus 6 Modes (Daylight, Shade, Cloudy, Tungsten, Fluorescent, Flash); +/-3 step adjustable Kelvin tempature control
• AF Illuminator Light : Yes, On/Off Select
• Clear RAW NR : N/A
• Histogram Display : Yes; Playback only
• Multi-Pattern Measuring : 40 Segment, Center Weighted, Spot
• EV Compensation : ±2.0 EV, 1/3 EV Steps
• Focus : Auto Focus: TTL Phase Detection, Multi-point: 9 Area, 8 Line, 1 Cross Sensor, Auto Focus Mode: Yes, Adjustable Spot AF: Selectable Sensor, Visual Focus Confirm: Direct via VF Matte Screen, Manual Focus: Yes
• Lens Type : Interchangeable A-mount
• Shutter Speed : 30 < 1/4000 sec 52 step, Bulb
• BIONZ™ Engine : Yes (LSI with Dynamic Range Optimizer (DRO/DRO+))
• Output(s) : Video: Yes, NTSC/PAL Selectable
• USB Port(s) : Yes, Supports USB 2.0 Hi-speed
• Operating System Compatibility : Microsoft® Windows® 2000 Professional, ME, XP Home and Professional; Macintosh® OS X (v 10.3 or later). OS must be installed at the factory.
• Supplied Software : Picture Motion Browser for Sony v1.1 (Windows), Image Data Converter SR Ver. 1.1 (Windows & Macintosh), USB Driver
• ISO : Auto/160/200/400/800/1600/ Lo80/Hi200
Sorry, product photos taken with my iphone
Sample pictures taken on a recent vacation
lkretvix
