Source of used 16" wheels?
Vandal
When my current tires wear out on my 95 SR, I was thinking I might switch to 16" wheels for the added tire choices and sizes.
Do Nissan, Toyota, Izusu, and/or GM six-lug wheels fit? I believe they are all the same pattern.
I assume I could run Montero Sport or later model Montero 16s.
Thanks guys!
off-roader
Sure they will fit the bolt pattern. Just be sure to verify the offset/backspacing also fit depending on the tire you choose. If you plan to ever upgrade to manual hubs, you also have to verify the center bore is big enough.
rxinhed
Dirt Guy
The later Montero Sport wheels have the larger hubs, correct backspacing and 2 or 3 patterns available. Nissan and Isuzu OE wheels have smaller hubs, and late model Chevy wheels are hub centric.
Vandal
Thanks for the info. I see a surprising number of Montero Sports rolling on 20in+ wheels, so maybe I can pick up some wheels cheap.
Houie
