Spacer s
dstock
Adaptitusa.com has a nice selection and will make what ever you want. I needed spacers for my new Dexter axle to clear the bearing hub because of the JK hub-centric wheels and ordered from them. No complaints. Check out my build to see what they look like.
Both mentioned above, plus Motorsport Tech can all make wheel adapters for you. I'm going to do the same thing as you to run JK 5x5 bolt pattern on my M416. I have read from several sources that they need to be 2" thick to clear the studs on the M416. Can anyone confirm that?
iStan814
