Spark Plug Order
Atrais
Got everything back together from my timing belt, valve seal job but it's got a rough idle. I'm going to check vacuum lines again and maybe take a look at the IAC but can someone confirm for me that the order of the spark plugs leads into the coil packs is (5,2) (4,1) (6,3) as you're looking at the engine? Just want to double check.
BEG
Take a close look at your intake, near the coil mounting locations. If I remember correctly, the order of the plug wires is actually cast into the metal.
Goldenbora
