gringorick
--- SOLD SOLD SOLD ---
This is an awesome Mercedes / Freightliner Sprinter 2500 158 RV, Gulf Stream Vista Cruiser, that has everything you need to get out and explore the world! I'm the second owner and this camper van is in great shape! The maintenance has been kept up to date and it runs like a champ. This RV is built on the highly sought after T1N Sprinter platform with the Bulletproof 5 cylinder Mercedes diesel engine. This is a 2006, the last year Mercedes built this model. I bought the van in 2018 with 100,000 miles on it. The previous owner had all services done at the dealer. I am a mechanic/engineer/fabricator and personally completed all of the services and upgrades since I've owned it.
Located in Lake Tahoe, CA
144k miles
Newish Michelin Agilis tires
16 inch alloy wheels
Bilstein shocks/struts
Sumo Shocks on all 4 corners
Two burner stove
Upgraded larger sink and faucet
Cold water filter for drinking
Instant propane hot water heater
Indoor and outdoor showers
Outdoor pop up shower tent
Upgraded toilet
Electric air conditioner and heat pump
Propane heater
2500 watt Onan generator
330 watts of solar panels
Blue Sky Mppt solar charge controller w/remote panel
Four 210 amp 6 volt golf cart house batteries
2500 watt pure sine wave inverter
Norcold 2-way refrigerator
50 quart ARB fridge/freezer/bench seat
Queen size bed with memory foam mattress
Dining table
Both Captain chairs swivel
All interior lights are LEDs
Multiple USB Outlets throughout
Flat screen TV for streaming
Tons of cabinet space
Custom blackout/insulated Window Coverings
Custom front door window screens
Fantastic ceiling fan
30 amp Shore power with cord and adapters
27 gallon freshwater tank
12 gallon black tank
12 gallon gray tank
Built-in RV propane tank w/ tee and hose for grill
Custom built rear drawer system
Lots of spare parts so you don't get stranded
Separate cab and house stereos with Bluetooth
Side door entry step
Backup camera
Baja Designs front LED lights
Carefree of Colorado full length awning
Emergency jump start switch
Exterior LED porch light
Tow hitch reciever
The only minor issues are:
The awning needs to be adjusted, it doesn't quite close up tight. Other than that it works perfect. Fully functional and secure while traveling.
The fantastic fan is original and will need to be replaced one day.
The microwave oven has been removed.
Some clear coat peeling on the paint.
Small ding on upper rear corner and rear bumper.
The driver's seat has a few cracks that have been repaired.
Normal interior and exterior wear and tear.
Maintenance/upgrades since I have owned it:
Replaced house batteries
Replaced starting battery
New turbo intercooler hoses
Turbo resonator delete installed
New rear brakes and rotors
New shocks/ struts/ bushings
Installed Sumo Springs on all four wheels
New Thetford toilet Aqua Magic V
New larger sink, faucet, and cold water filter
New Shurflo house water pump
New Excel instant hot water heater and exhaust fan
Added entire new solar system
Added extra house battery capacity
New ProWatt inverter
Installed multiple USB Outlets throughout
Custom heat shield over exhaust to keep the floor cool
Added insulation to exterior walls wherever I could access
New radiator and flushed fluids
New engine cooling fan and clutch
Transmission service and filter
New crankshaft pulley, vibration damper, and seal
Replace fuel injection pump o-ring
New water pump
New serpentine belt and idler pulleys
Replaced most hoses and have spares
Replaced most sensors, EGR valve, etc w/ spares
New thermostat
New alternator
144k miles
Two burner stove
Upgraded toilet
Propane heater
Dining table
12 gallon gray tank
Backup camera
Tow hitch reciever
New water pump
New thermostat
New alternator
