My upper and lower control arms are squeaking horibaly. I can't seem to find bushings for them. My OME suspension is on its way and want to figure this out before I tear the truck apart. Thanks
Toyota doesn't sell just the bushing, you have to buy the whole arm...IIRC Raybestos, AC-Delco, and others make replacements...or go to poly-bushings from Energy Suspension...the polys will need to be lubed from time to time to keep from squeaking.
Are you sure it's not a ball joint squeek
With no grease zerks what would you use to lube them? I can use lithium fron a can but that may be a continuos thing. Thanks for the lead on Energy Suspension.
Not sure that its not one, the squeak is on both sides and more so on the driver side. I don't remember seeing a grease zerk there.
Thanks
