Stability Control wiring???
offthepath
I got a new 03 Montero and while driving it back the left front tire blew, taking out the inner fender and it got into the wiring harness. Right after it happened the left front turn signal would not work but everything else was fine.
Once I got it home I starting looking and the turn signal bulb was blown so I replaced it, but it still was not working. I traced the turn signal wire back through the harness to the firewall and there were no breaks or chafed wires. There were a few that had kinks in them that I straightened. While looking through the harness I did not see any apparent damage to any wires, but now the traction control "OFF" light is on and the traction control will not come back on when you push the switch. I am guessing while looking though the harness there is internal damage to the wires and playing with them broke the connection.
Does anyone know what color the traction control wire in the main harness is? Or if not how could I figure out which wire in the harness is for the traction control? I have the factory service manual, but it did not have the color codes of the wires.
Thanks.
offthepath
Disregard, I guess when the battery is disconnected you have to drive the car a bit to reset the traction control. All works now.
