Stick Figure
Figured I would share some progress pics of my 4Runner Hide-A-Bed.
First off the criteria for this:
Sleep two reasonable comfortably
Keep the fridge inside the vehicle (preferably with out moving it)
I wanted it in time to hopefully have a little bit more adventure possibility on our x-mas trip
Needed to be able to arrive at our destination and be able to use the rear seat again.
That being said:
Borrowing a photo of my truck from SantaCruzRunner over on the t4r.org forum ... the previous set up:
Tools and recovery gear on the drivers side, and the fridge on the right.
on to the new set up:
Fully closed up:
No fridge blocking the view:
Step one: unbolt and remove the rear seat bottoms. (Hey I only said they had to stay, not stay in place!) Place seat bottoms under rear storage.
Step two: Screw the 6 1" legs into place
Step three: flip platform out
Step four SHOULD be the same as 2, but I haven't gotten that far yet, so anything can change.
Step five: front seats need moved forward and flipped forward
Step six: flip final platform out.
Again I am planning on using more screw in dowel legs, as long as they work for that position too.
and a couple other angles.....
Wood is all MDF Other than the 1" dowels. Yes MDF is heavier than plywood. I still used it for a couple of reasons.
Easy to work with and shape.
Nicer finish on ends than plywood.
LOTS more experience working with it.
Can be strengthened by impregnating it with fiberglass resin.
Overall length of just the platform is right at 67" and width is at 48". I would have liked longer, but the fridge is too damn big and this is a 4Runner not a Land Cruiser.
Absolutely open to all questions and comments. This was a design as you build proposition so i'm sure there are some things I haven't thought of.
a few more pics http://www.mostdesigns.com/zgallery/Personal Vehicles/4Runner/Sleeping platform/build pics/
Fully closed up:
