Step up/down converter?
SootyCamper
For those with rigs that utilize euro 220v appliances, which step up/down converter are you using? I'm looking to utilize some 220v appliances in my new build and some of the converters I've found have less than stellar reviews.
Perhaps a whole seperate inverter is used? I am using a 48v system.
Anyways, looking to use the Daewoo wall mounted mini washer/dryer.
Darwin
Euro is also 50 hz, so the converter would have to change to that as well. I haven't looked into them that much other than for standard NA 60 hertz appliances.
I would say if Victron doesn't make one that will do it, you would probably need another separate inverter.
