Suburban Tiers
joker_fly
Well i finaly got me a burb =) 1500 4x4 1995 350/700
Now im looking in to tires and i need help =)
How big can i go with only doing a cutout fender mod? (More about this later)
im Currently running 285/75 16 (33"?) but it looks so small and skinny
Need a good open M/T tread and WIDE tire rim combo, dont do mudding only snow wheeling
Any Ideas ?
Im thinking of doing a fender cutout mod but im wondering what the real gain is ? will bigger tires fit ? and how complicated is it ?
I want to runn 35" but i dont want to lift it
Kim / Sweden
Northman
Hello Kim , 33" is the Maximum without any Lift . For 35" you have to cutting the Front Fenders on the Rear Side 2-3" . But i think , 33" is more than enough for your Axles . If you only want to cruising in Snow , M/T's are not the right Tires for you . Do you have any Pics of your Truck ?
Greetings from Germany
Peter
bftank
maybe some wide mickey thompson's seems to be popular in ice land. those trucks are usually lifted a little though.
joker_fly
Thanks for the answers
But i know what tiers im getting so i dont need help with that thanks any ways
the problem is i dont know how big i can go with cutout fenders and no lift
78Bronco
I would think you can stuff 35's without any issues with some trimming and no lift. First do not run a 15x10 wheel because it will push the tire outboard and require more trimming. Stick with a 15x8 wheel with a neutral offset.
the biggest drawback will be stopping the rust after you cut the metal and expose fresh sheetmetal.
I wouldn't hesitate to go to your local tire dealer and have them test fit a 35x12.5" tire for you so you can see how much you need to trim.
When aired down an M/T tire works fine in the snow and IMO is far more versatile than A/T tire. I like BFG's and the Cooper would be my first choice as they give good bang for the buck.
bftank
sorry you r post made it look like you were looking for tires as well. long story short anything wider than a 12.5 wide tire will either rub the wheel well or the fender.
