taco007
Hi: Can you experts here check my plans please? I have a 17 4Runner and am planning on running a National Luna Fridge. I'm planning the following, in hopes of future add ons:
4 Ga, with Bussman 60 amp circuit breaker near battery, wire run along door plates and into fender area in rear cargo (driver's side). I would like to terminate to a Blue Sea 6 place fuse block, and then run my fridge off that. My concern/question is any issues attaching the heavy Ga wire to the fuse block? Can I step it down to a smaller wire to attach to the fuse block (I don't think they make 4 Ga. to the small screw/post on the Blue Sea box. I would run a negative/ground to the body panel of the truck.
Also, If I do this, can I get away with only running one 4 g wire (positive), or do I need both pos and negative? (Silly question but I'm new to this flowing electron stuff)
Thanks in advance
Thanks in advance
