Sunforce-Solar 12 Volt Battery Trickle Charger
Toolman
No advice on the the charger but for your trailer I would recommend a blue marine optima battery for the trailer.. they are designed to be discharged and then charged up again as the red top is mainly designed for starting purposes. Yellow is dual purpose starting and for electronics..
stioc
njjeepthing, your link doesn't work. I found this article easy to understand and helpful when considering a solar powered charger:
http://fiberglassrv.com/solar.html
In most cases you need a 50-60W panel. Those little ones are only good for providing maintenance charge for storage AFTER you've already fully charged the battery.
