Sunsaver 10L question
SwampMonster
Im building one of the pelican box batteries and have a question.
Is it possible to use the solar input on the controller to plug in to 12v dc in my rover to charge the battery. I would like to make one cable that will hook up the solar panel or dc to the rover to cut down on plugs on the outside of the box.
Sent from my C811 4G using Tapatalk
unseenone
Do I understand you correctly, you want to input from your engine battery to the solar input to charge your spare battery, connected to your solar setup.
No, I would not advise that. What kind of rover to you have?
SwampMonster
I have a 2002 disco with dual batterys in the works. This however is a self contained portable battery box with a small odyssey PC680 to use while camping to not have to pull of the Disco's on board system. Kinda like a jump box. Want to be able to charge it by solar/on board 12v and 120 with the battery tender.
iStan814
