Superline - the next generation of synthetic ropes.
Master-Pull
Supporting Sponsor
Many of you may already be familiar with Master-Pulls line of synthetic ropes. We are the only company to offer different grades or qualities of rope that include MP Basic, Superline and Superline XD. Master-Pull Superline is a rope unlike any other out there. By starting with a larger diameter synthetic rope a unique manufacturing process allows Superline to be stretched down to a smaller diameter, this retains the strength of the larger diameter rope while reducing the overall diameter of the rope. This gives the highest strength to size ratio available for any rope available!
Because of the manufacturing process, Superline is a much denser and tighter woven line then lines like Amsteel Blue. This reduces the likelihood that a strand will catch while winching and damage the line. The dense packaging of the fibers helps keep grit from working their way into the line and damaging the rope.
The strength of Superline allows for a smaller line diameter to be used on a winch and also for more rope to fit on a drum. Check out the strength of Superline vs regular synthetics:
• 5/16ths Superline 21,000 lbs 5/16ths Amsteel Blue 12,300 lbs
• 3/8ths Superline 26,000 lbs 3/8ths Amsteel Blue 18,000 lbs
Here is a picture of Master-Pull Superline pictured with our new Winch Stop Thimble:
Like all Master-Pull products, these ropes are elligiable for a 10% discount. If you need a quote or have a question about which rope is right for you contact us and we can help you out.
To place an order call: 360 714 1313.
-Alex
Master-Pull
Supporting Sponsor
I should add that we have 7/16ths Superline in stock. It has a rating of 40,000 lbs, perfect for larger winches!
-Alex
Riptide
What does the Winch Stop Thimble sell for? I didn't see it listed as an option on the site...
Thanks in advance.
Master-Pull
Supporting Sponsor
Until we launch our new websites our winch stop thimble is only available to over over the phone.
-Alex
Master-Pull
Supporting Sponsor
Superline gives you the most strength for the least cost, check it out before you purchase your next rope!
-Alex
DamMan
I have seen Master Pull Superline in smaller ATV sizes on one reseller website but nothing on the Masterpull website. I am just curious if Master Pull makes 3/16" and 1/4" Superline or is some else copying the Superline?
Master-Pull
Supporting Sponsor
5/16 x 100 with the winch stop thimble: $416.88
3/8 x 100 with the winch stop thimble: $491.51
Those are the retail prices, take 10% off for the expo discount and you will be at: $375.19 and $442.36.
-Alex
Master-Pull
Supporting Sponsor
Bringing this back up, we have multiple sizes that aren't on our website. If you have a question feel free to drop me a line on here or give us a call and I will do everything I can to help you choose the correct rope for your application.
-Alex
Goldenbora
