Hello Ladies and Gentlemen, I drive a 2011 Ram 1500 ST Single Cab 4x4 with the Tow Package. Purchased the truck for cheap (pretty sure it was a work truck hence the 5 wheel hole in the bed) came with 265/70/17s these looked incredibly small, so I upgraded to 285/70 17s in Cooper ATP's(discount tire special). I didn't want to go to large with 35's later I might step up to 285/75's.
Now onto the question. I want to lift it. I don't feel like I need much maybe just a level seeing my nose enjoys eating the ground every time I go off road. I daily drive this truck I'm not much into the whole mudding thing, just exploring nature hitting up places like marble falls, and big bend type terrain. So my options are...
Rough country 3.75 level a spacer lever with a 1 inch body lift Pros-Cheap minus body lift install price
Cons-I was told to avoid all spacer lifts due to the fact the hinder shock travel
Bilstein 5100's adjustable-Pros-From what I've heard build to allow full travel when adjusted to level
Cons-A bit pricier then the Rough Country
Lastly I was looking at a ICON Stage 2 package Pros- I'll sit level, amazing ride, increased travel
Cons- Almost 2 thousand dollars
What would you do? I do offroad a decent bit, should I just start saving or will the Billies or RC level be fine?
Lastly the truck has air shocks in the rear should I keep those or replace them when I do the suspension upgrade?
