Suspension Fault Code via GAP Tool
Gunnslinger
I have had a Red Suspension Fault indication followed by lowering to the bump stops twice in the last month. GAP tool fault codes below. I am thinking it's time to replace an Exhaust valve. If anybody has experience with this failure, I would be grateful for your feedback. FWIW, turning off the car and restarting it has fixed it both times and the GAP tool has been able to clear the faults.
Cheers
Suspension
C1A36-01 (2E) Exhaust valve - General failure information - general electrical failure
( at 100390 km )
C1A07-62 (2E) Cross articulation - Algorithm based failure - signal compare failure
( at 100390 km )
Abran
Exhaust valve is your conpressor.
Cross articulation Fault is probably a leak.
Get the vehicle to standard or off road height, measure all 4 corners then disconnect the EAS fuse(I think F26) or disconnect the battery.
Wait 12 hours and re measure. You can find what corner has the leak.
If no leak, try an EAS calibration.
Gunnslinger
Fantastic. Thank you. I'll give that a shot and report back!
iStan814
