Swedish Military 30" Bow Saws $34 Shipped!
Jerry Ward
Super high-quality bow saws!! I have used the Swedish military saws extensively in the field for years; from traplines in Alaska to desert expeditions in Utah. I average 100 nights per year in the field living on the trail away from my rig bushcraft-style, so my tools get worked hard and must perform flawlessly. I can tell you from experience that this is a great tool that you'll own/use for years! The 30" blade allows you to process larger material with less work as opposed to the common 24". Much higher quality than the Chi-Com garbage found in big box stores. These actually cut wood, hold an edge, and can handle the rigors of use in the field. Features a thick steel frame, sharp Swedish-steel blade, and wooden blade cover. I have three saws available. All three are in used condition with several older coats of paint on the frame. The blade covers may be cracked/split, but still function just fine. Thirty inch long blades are either brand new in the plastic or like new. All three saws vary just a little, but are genuine Swedish military surplus. A few even have the Tri-crown marking! All three in working, functional order. Uses common 30" replacement bow saw blades found at many stores and online. $34 shipped anywhere CONUS; or pick them up local here in Berryville, Arkansas. Thanks, Jerry
New price of $28 shipped!!
jeep-N-montero
I have one of these and picked up both the wood and metal blades for it, Ace was the only place I found blades for it locally but worth it.
Jerry Ward
I discovered 2 additional saws when clearing out my shop, so a total of 3 still available! $28 shipped anywhere CONUS
