#t4rv3 1999 4runner Limited build thread
Tuanvuyeah
Had some custom rock sliders built (xo-fab) to length since there was nothing on the market that I believed suited my wants/needs 505291505292505293
Had some custom “pine tree” gussets made just for some personal customization and added strength
505294505295505296505297505298505299
4 point strength test lifting up vehicle505300
Tuanvuyeah
Rock slider install continued
505301
Prepped metal with por15’s degreaser then their metal prep. 1st layer of por15. Dried for about 2 hours, then another layer and sprinkled sand on top and let that dry for two hours. A third layer of por15 followed by bed liner on top and rubberized coating on bottom/frame sections to minimize chipping.
505302505303505304
Tuanvuyeah
New oem fuel pump cause I’m sure it’s still on the original one. One of those “just in case” items checked off the list 505307
Saint Nick
View attachment 505302View attachment 505303View attachment 505304
Very nice bar work and welding (y) Glad to see you've fixed the 'punctures' ;)?
Nick
Saint Nick
Marlin crawler rear diff armor (1/4” thicc)
View attachment 505308View attachment 505309
Had to drill out and remove all the mounting brackets/hardware to fit the cover on
View attachment 505310View attachment 505311View attachment 505312
Hardware brackets reinstalled
Metal prepped/etched (zombie lookin)
Por15’d the whole section then finished off with silver for the armor plate and rubberized coating on the rest of the axle View attachment 505316
More nice work (y) Does the armour come in parts that you have to weld or pre-welded?
Nick
Tuanvuyeah
Drove up to Canada to pickup the skid kit that I ordered 505317
505318
Front diff/transfer case/gas tank skid kit505319
505320
Had the ability to use my shops lift to make this a little bit less of a PITA
505321505322505323505324505325505326
Lined up! Most of my skids setup
Tuanvuyeah
Decided to box and weld on my lotus lower link skid. I understand their design but also understand that upon sharp or hard impact, the lower links can still crumple up and get damaged. Eimkeith makes a great weld on one but I preferred to box the entire link so if there is ever impact load, the whole entire link is boxed to the frame giving it no room for damage (if I do manage to damage it, I probably broke a bunch of other things too lol)
505330505331
Had to drop the gas tank again to weld on the driver side reinforcement plates.
505332
505337505333505334Not the cleanest welds, but proper penetration and function is more important. Some of the most awkward welding angles I’ve experienced laying on the ground 505335505338
2x por15 coats/rubberized coating/silver paint 505339
