tech question
I have a 1997 Land Cruiser and have a leak ( kooks to be oil or trans fluid) under the radiator on the left hand side. Can anyone help with a fix? Thanks in advance.
S
Scenic WonderRunner
Guest
I have a CSF radiator like in this link in my 4Runner. I was trying to get you a pic, but it's a bad pic.
http://cpwstore.carpartswholesale.com/catalog/?PN=9235&N=0&VN=4294967267+4294967152+4294965467+4294967247+4294962026&Nr=AND(universal:0)&sv=0
So you should have a built in tranny cooler in the bottom of your radiator. If it's tranny fluid leaking, the color would be more on the red side.
I would start by trying to tighten the two clamps on the two small tranny hoses that enter and exit the bottom of the radiator.
Welcome to ExPo.....!:safari-rig:
Here is the drivers side. See small tranny fluid hose just to the right of the radiator hose. I just had a new (free/warranty) radiator installed at my engine rebuilders. Their mech. messed up my radiator outlet by putting the hose clamp on wrong! So I've been under my truck dealing with leaks also. I hate that!
OlympiaFJ60
You can also have a leak (if it is oil) under the timing cover on the 1FZ. As mentioned, search on ih8mud.com in the 80 series section.
Goldenbora
