TeraFlex JK HD Hinged Carrier & Adjustable Spare Tire Mounting Kit
TeraFlex
TeraFlex JK HD Adjustable Spare Tire Mounting Kit (You can pre-order this part but it will not ship until the beginning of September.)
Part# 4838130
MSRP $199.99
Includes:
• Tailgate-mounted base plate
• Adjustable tire mount
• Wheel studs
• Brake light mount
• Spacers
• Protective gaskets
• Assembly hardware
• Product Installation Instructions
Part# 4838150
MSRP $699.99
Includes:
• Cast Aluminum HD Hinged Reinforcement Plate
• Wheel studs
• Brake light mount
• Spacers
• Installation & Assembly hardware
ONLY WEIGHS 40LBS COMBINED!
Part# 4838100
MSRP $499.99
Includes:
• Cast Aluminum HD Hinged Carrier
• Spacers
• Installation hardware
TeraFlex Inc., manufacturer of TeraFlex suspensions, body protection equipment, low range gearing and HD axles, introduces the newest heavy duty component for the JK Wrangler.
The TeraFlex Heavy Duty Adjustable Tire Carrier & Tailgate Reinforcement Kit is designed to carry up to a 37" tire over the most extreme trails and obstacles, and provide easy and immediate access to the rear cargo area with a single action.
The TeraFlex Heavy Duty Adjustable Tire Carrier & Tailgate Reinforcement Kit spreads the load and weight of the tire to more than just one hinge point. Incorporating and using the factory tailgate hinge mounting points spread and separate the load as far apart as possible, resulting in maximum strength and durability.
Dedicated tooling provides a cast A356.2 T6 Aluminum main component. This keeps the carrier as light, and strong as possible. The fit and finish is designed to follow the flow and contour of the Jeep tub, while seamlessly providing additional mounting points for off road accessories such as recovery jack and fluid containers. The factory Jeep tub provides substantial internal gussets and bracing that easily supports the new tire carrier and oversized tire. The HD hinge brackets are forged steel and the HD 5/8” hinge pins are constructed from cold formed high-carbon hardened steel. The combination of mounting location and HD mounting brackets provides one of the strongest, rattle-free tire carriers on the market today. The TeraFlex HD tire carrier removes all stress from the gate by utilizing the HD reinforcement carrier as the load-carrying component, in effect it carries the weight of the tailgate assembly and the spare tire.
Product Features & Benefits:
• Lightweight aluminum
• Maintains single one-handed entry to the Jeep cargo area
• Allows adjustment for up to 37" tire
• Threaded mounting holes for mounting accessories (fuel cans, recovery jack, etc.)
• Eliminates tailgate stress and rattles
• Simplicity and Ease of installation - installation can be performed using common hand tools.
• No drilling required.
• Factory form fitting geometry and finish. CAD-designed tooling follows the precise compound curvature of the Jeep body, resulting in a carrier with an OEM appearance.
• No aftermarket bumper purchase required – works with OE and aftermarket bumpers.
TeraFlex products are available direct, or through authorized TeraFlex Dealers. For a complete list of Dealers in your area, or to purchase direct, contact TeraFlex at 801-288-2585 or visit them on the web, TeraFlex - Upgrade your Jeep | TeraFlex Suspensions.
The TeraFlex Heavy Duty Adjustable Tire Carrier & Tailgate Reinforcement Kit can be purchased complete or individually to fit your specific needs.
Termas
Not that it means much, but my tailgate with a Teraflex spare tire carrier survived an decent impact. I was rear ended in LA yesterday with only the original plastic tire holder failing.
For what it's worth. Pics of the Jeep and the Honda.
