TeraFlex Product Highlight: JK Tera44
TeraFlex
http://www.teraflex.biz/jk-tera44-heavy-duty-front-replacement-axle-housing.html
TeraFlex JK Heavy Duty Replacement Axles are the perfect solution for bent, broken or damaged front axles in JK Wrangler and Rubicon vehicles. The Tera44 offer a direct bolt-in upgrade for Jeep JK owners looking to beef up the weak areas of their front axle. These axles have been engineered for extreme use and feature 3.25” OD x .25” wall DOM tubing for superior strength. Forged inner knuckles increase section strength to eliminate ball joint separation.
The replacement housing includes a heavy duty housing, tubes, axle bracketry, and forged inner knuckles. Pre-installed inner seals and upper control arm bushings make the upgrade seamless. Simply transfer your existing internal components, outer knuckle assembly, and brakes to the new housing!
Tera44 HOUSING Assembly Features & Benefits
• Forged Heavy Duty Inner Knuckles with greater upper and lower section strength
• 1/4” Thick CNC laser cut axle brackets for extreme strength
• Reinforced front trackbar mount (ties into spring pad) for greater strength
• Integrated lower FlexArm skid plates
• Pre-tapped hole on spring perch for bump stop extensions
• Pre-drilled holes for limit straps and lower spring retainers
• Heavy duty ductile iron differential cover
• Axles Seals pre-installed
• Pre-installed upper control arm bushings
• Retains all JK ESP, ABS & Speedometer sensor capability
• Proper pinion angle for lifted JK applications
• Premium UV protected triple-stage powder coat process for superior corrosion resistance
• Ductile cast iron housing with increased rib gussets
• Smooth radius bottom design to glide over rocks & obstacles
• Asymmetric housing design, for extra long tube side strength
• Bottom oil drain hole for simple fluid changes
• Integrated factory location upper control arm mount
• 3.25” x 0.25” axle tube increases strength to resist bending and torsion with minimal weight increase (6.7lbs more than factory tubes, 8.9lbs less than sleeved axle tubes)
• Compatible with factory JK Rubicon locker (R44 model only)
• Includes adapter fitting for ARB and Detroit lockers (TF44 model only)
• 100% engineered, designed, and built in the USA
• 100% new components
• No Excuses warranty - 1 year, unlimited mileage
JK Front Tera44 Rubicon Replacement Housing
3” O.D. x 1/4” Wall Axle Tube
R44 - For OEM Rubicon or compatible Lockers*
JK 0”-3” 3544000 $2049.99
JK 4”+ w/ raised pinion angle and trackbar bracket 3544004 $2049.99
JK RHD 0”-3” 3544001 $2049.99
JK RHD 4”+ w/ raised pinion and trackbar bracket 3544003 $2049.99
TF44 - For Dana 44 lockers (non rubicon)**
JK 0”-3” 3544200 $2129.99
JK 4”+ w/ raised pinion angle and trackbar bracket 3544204 $2129.99
JK RHD 0”-3” 3544201 $2129.99
JK RHD 4”+ w/ raised pinion and trackbar bracket 3544203 $2129.99
3” O.D. x 1/2” Wall Axle Tube
JK 4”+ w/ raised pinion angle and trackbar bracket 3544053 $2229.99
JK RHD 4”+ w/ raised pinion and trackbar bracket 3544054 $2229.99
JK 4”+ w/ raised pinion angle and trackbar bracket 3544253 $2259.99
JK RHD 4”+ w/ raised pinion and trackbar bracket 3544254 $2259.99
*Note: The R44 axle is designed to work with factory axle shafts and Rubicon locker 68017176AA or the OX D44-JKR-30. The ARB RD157 or the OX D44- JKR-35 lockers can be used with new 35 spline axle shafts.
**The T44 axle is designed to work with non Rubicon Dana 44 lockers. Please consult the Tera44 axle flow chart prior to placing your order.
Houie
