The Dirtlab lives on... as Falkor!
I am the lucky individual that purchased @AuntieM's F-550 based Dirtlab: Build Thread
I cannot thank @AuntieM enough for this dream rig. I live full-time in it and spend most nights on BLM in the Rocky Mountains west of Denver, CO. Here's some of what I've been waking up to lately before work:
I am ready to make some upgrades to Falkor and would love anyone's input.
Existing Upgrades:
  • BPD EGR
  • BPD Oil Cooler
  • Edge Insight CTS
  • Monroe HD Shocks
Proposed upgrades:
  • Exhaust: MBRP 4" Cab & Chassis Turbo Back Single Side Exit T409
  • Exhaust Brake: Pacbrake InLineMount 4'' PRXB
  • Head Bolt Conversion: ARP Head Studs
  • Turbo: KC Stage 1.5 Drop-in
  • Tuning: SCT X4 w/ Edge Insight CTS2 or just SCT LivewireTS?
  • Suspension:
    • Front: King 2.5 Coilover Remote Reservoir, compression adjusters, custom valving w/2.5" lift (lift necessary for wheels to fit)
    • Rear: King 2.5 OEM shocks, compression adjusters, custom shock mounts to angle rear instead of front, Deaver leaf springs w/ 2.5-3" lift
    • King Steering Stabilizer
  • DRW to SRW conversion: 1st Attack Engineering direct bolt-on conversion wheels (requires trimming both front and rear wheel wells)
  • Tires: Continental MPT81 335/80R20
  • Leveling: Quadra Bigfoot Automatic Leveling System
If anyone knows of a reputable shop in Colorado that could do all the work, it would be a lot easier than having to bring it to multiple locations.
After more research and advice from the powerstroke.org forums, I've added the following to the upgrades list:
Kill Devil Diesel Heads
BPD Water Pump and Fan Clutch
BPD FICM w/ Atlas 40 tune from FICMRepair.com
S&B Cold Air Intake
ATS Coolant Recirculation Kit
Odawg S3R Ported Intake Manifold
Odawg Coolant reroute w/PSP Race Tank
Inner Double Beadlocks for tires
Any final suggestions before I start ordering parts?
Thanks!
bknudtsen
Good battery health is critical to keeping the FICM healthy. Don’t skimp on the charging system and battery bank. Low voltage kills FICM’s.
Quick update:
I made some changes to parts again then took the mechanical plunge and decided to install the ones I thought I could do on my own. I finished the following and LOVE the results so far:
BPD Water Pump & Fan Clutch
No Limit Hot/Cold Intercooler Pipes
No Limit Cold Air Intake
DC Power 270XP Alternator w/ wiring kit from FICMrepair.com (Thank you @bknudtsen for the charging upgrade suggestion)
PSP Degas Tank
IPR High-Flow Coolant Filter
Air intake required a cover for the MAF port as the 2005 model did not use one. I have the IAT probe temporarily zip tied next to the aFE filter but will eventually bore a hole in the MAF cover for it (I didn't have the right size bit or grommet during installation).
MPG went from 9-10 to 11-13 as reported by CTS average, tested from 3000ft-10,000ft altitude over 1500 miles. Stock turbo spools faster at lower RPM. The rest of the parts are scheduled to be installed the week of 12/10 now that I finally found a shop that could fit the rig.
I am holding off on the suspension/SRW conversion for now as I decided to quit my job and spend that money going on a 6-month adventure through the Western USA and Canada. I may do just the coilover conversion and rear shocks without any lift or Deaver leaf springs; has anyone here done a Super Duty King coilover conversion already that can speak to the results?
I'm hoping the shop doing the work in a few weeks will let me document the progress in pictures/video so I can share with you - I'll keep you posted!
dhuss
