The Get Away Van – 2020 Ford Transit LWB Van Haus Conversion - $119,000
VanHaus
New 2020 Ford Transit long wheel base van, Seating for four and can sleep up-to four (two adults and two children) or three adults thanks to a Fasp 505 two person bench seat that converts to a bed using the two front seats to save on space. The main bed is a large platform bed in the rear with a 6″ queen mattress. This van features large upper cabinets for storage, a large gear garage with a 60″ slide out kitchenette with induction burner or can be used for additional gear.
More photos here https://vanhausconversions.com/2020-ford-transit-lwb-the-weekender/
Van Information
  • V6 Engine
  • Keyless Entry Code System
  • Ultra Toil 450SB 16″ Wheels
  • BFGoodrich All-terrain T/A KO2 Tires 245/70 R17
  • Power Steering
  • Rear View Camera
  • Backwoods Mods Rear Bumper
  • Powerful Pathfinder LED Back-up lights
  • Aluminess Spare Tire Carrier
  • Trailer Tow Hitch (2”)
  • Cruise Control
Conversion Specs
  • Two Person Sofa/Bed
  • Driver and Passenger Factory Swivel Seats
  • Four Season Insulation Package
  • Marine Grade Decking
  • Duramax Durable Fabric Interior
  • Overhead LED Lighting
  • Under Cabinet Tap On Direction Lights
  • Step Light
  • Porch Light
  • Large Driver Side Awning Vented Window
  • Two Awning Vented Bunk Windows
  • Wrap Around Upper Cabients
  • 24 Gallon Fresh Water Tank
  • Rear shower/Spray Port
  • Slide Out Kitchen with Single Induction Burner
  • Dometic CFX345 Electric Efficient Cooler
  • 200Ah Lithium Battery System
  • 300 Watts of Solar
  • DC-DC 30 Amp Charger
  • 2000 Watt Pure Sine Xantrex Inverter with 80 amp charger
  • 5 Duplex High Power USB Charging Ports
  • 3 12 Volt Charging Ports
  • Ventilation Fan with but-in rain guard, 10 speed reversible motor, and remote
  • Dual Removable Bamboo Tables with Swivel mounts
  • Gas furnace coach heat by Webasto
  • Privacy Window Coverings
  • Large 10′ x 8′ Awning – F45S by Fiamma
  • Recessed and Surface Mounted L-Track with lovable D-Rings for securing gear
$119,000
Psyph
