ExpoMike
BTW, the AX15 gear ratios are as follow (found on NAXJA)
1st. 3.83
2nd. 2.33
3rd. 1.44
4th. 1.0
5th. 0.79
5th gear IS an overdrive. Outside of BMW, most 5 speeds, 5th is an OD ratio. Also, everything I am reading says, the AX15 and 4.0L equipped XJ's have 3.07 ratio axles. Looking at the ratio of the tranny, I would look at 4.10's, otherwise 1st might be useless on the street.
I know with my AW4 on 31's, I pull 19-21 mpg highway, as long as I stay under 70 mph. Even towing our Kamparoo, we get 17-19 mpg, again keeping it about 65 mph. When I get into the hills, I end up using 3rd most of the time, which doesn't really hurt the mileage. From what I have read, because the torque curve is fairly flat until about 3500 rpm's, the mileage doesn't drop off nearly as much, even when towing, then a lot of other vehicles.
1st. 3.83
2nd. 2.33
3rd. 1.44
4th. 1.0
5th. 0.79
