Thoughts on rear wheel spacers (SMB what do you think?)
medicfernando
I have a 2003, 7.3 4x4 SMB. It has the stock rear semi float axle, which is a little narrower than the front DANA 60. I am considering rear wheel spacers to match the width of the front but have heard that this will wear out the rear wheel bearings. How much quicker will this happen? Does anybody have experience with this? I know Ujoint makes spacers, what do they say or recommend? Any input or experience is welcome. Thanks in advance. Fernando
LoRoad
Not sure if this helps the conversation here or not, but....my first 'car' was a 69 Land Cruiser. The front axle was wider than the rear. It seemed, key word here 'seemed', to me that this helped create a better platform for off-roading, of which I did a lot. My question would be - why bother setting the the width to match if there isn't a problem?
grogie
Like to Camp
From what I've read, people that use spacers say that their safe, but they do have to be checked on a regular basis. I don't think bearings is as much of an issue. Personally it's just not something I'd want to bother with or worry about. As said above, if it's not an issue in the first place I'd go on without them.
Cool van, btw!
robgendreau
Your van was designed with a wider front than rear. For offroading, that can be a problem in that the front track is slightly wider and hence the rears might hit something the fronts don't. But that's probably insignificant on a big ole SMB. Especially considering that adding spacers adds a signifcant failure point on the van. When I used spacers on the track I had to constantly inspect them. I've seen wheel on spacers come flying off a SMB offroad, and go sailing off down an embankment. Not pretty. The thought about bearings is that since weight is moved out on a lever, it puts more stress on the bearing. Seems intuitive, but I doubt you'll find data.
I suspect the difference isn't that large. If you feel the need to make the rear bigger, consider as a first option getting front and rear wheels with different dishes so as to bring them more in alignment; you might be able to get them equal without impinging on brakes and without the need for spacers. Indeed, you might be able to bring in the front enough to match the rear.
Abitibi
Main issue with different wheel offset is when comes time to rotate your tires...
Sent from my iPad using Tapatalk HD
Saline
My semi float 60 in my 04' SMB was trashed at 54k miles. There was a lot of play in the bearings, enough that the rear tires were wearing unevenly. It had the spacers from SMB as well. In all honesty if you do a fair bit of off roading fully loaded I would either not put spacers on or change out the rearend to a full floater. I replaced mine with a D70 and it was wider than the semi float so it didn't require spacers to have the same track as the front.
SMB's should all come with full floaters IMO, they are heavy machines.
medicfernando
Thanks. I plan to go with a full floater and ARB in the next year or so hopefully.
