Time to "Re-tire"...
voyageur
I am ready to buy a new set of tires, for my 1996 'Overy I. It has a 3" lift and plenty of above-tire clearance. Currently running: Wild Country TXR, LT245/75R16, Load range "E". (They rub the inside wheel wells at full lock).
I want a more aggressive, self cleaning, tread - don't mind tire noise with more flotation, for our Florida sand and mud.
Intended use 70% paved 30% unsurfaced...
I would apreciate: comments, suggestions and experiences with a good tire for my application.
Thanks...
voyageur
Thanks!
Thank you Kellymoe...
Great price too. I am going to order five of the "Warden's" in my tire size. I appreciate the tip.
Regards...
voyageur
Timmy...
Big Cypress Wildlife Area, is one of the places we frequent. They have several clasification of ORV's and a strict inspection program. They require "Minimum 9" of tread face" I want to make sure that whatever tire I get, it will meet that 9" minimum.
Of course you are correct about the current reduction in my turning radius due to the wider than normal tires...
Thanks for your input.
S
stu454
Guest
Probably either floatation in the mud or digging down and getting stuck on the frame rails, if I had to guess.
jrose609
I've never heard of those tires. They are definitely priced right. Has anyone used the Axioms? I would like to get those for a winter tire. Looks like they would be good in the snow and ice. Anyone have any experience with them?
voyageur
I believe the perception is that the wider tires will minimize the damage to the earth. Fat chance! All the giant tire, Yahoos tear it up anyway. Nothing against Yahoos. I probably am one. Just stating the facts... :truck:
The more mud on their trucks the happier they are.
Tiny tire Dave
SeaRubi
if there's no bottom to the mud, a wider tire can have it's advantages. have you considered 285/75? That's roughly 33" in diameter, and easily meets your width requirements. Aired down would give you a bit of float. Adjust your turn stops to get rid of the rubbing. Or consider offset wheels, or using wheelspacers.
cheers
-ike
wanderer-rrorc
I have bfg Commercial traction TA's....235/85/16 flavor...E rated...love them!!
clean good...great traction...more of a AT than a mud tire..but I cant knockem!! they work great!
http://www.tireteam.com/Tires/BFGoodrich/Commercial+TA+Traction/2358516/58509.html?&ref=GBASE
Goldenbora
