pratty85
About a year ago I changed my timing belt and tensioner in my Defender's 200tdi. The previous belt had been making contact with a bolt that holds the crank case to the block, I assumed that was the reason the belt was slowly peeling off the inside. I replaced that bolt with the proper one when I changed the belt. A week or to ago I was going through everything, and noticed some belt shavings inside the housing, so I ordered up a new belt and proceeded to take everything apart again, this time everything came apart smoothly thanks to my old friend anti-seize. What I discovered this time, was not only the belt shredded it was starting to wear the inside housing, so I began to investigate what was pushing the belt into the housing. What I found was that the cam gear, crank gear, and injection pump gear were all wore down on the inside teeth.
So this lead me to think what would have caused this to occur, so I took a straight edge and checked to see if one of the gears was was not aligned with the other two. The injection pump gear is slightly inset compared to the cam gear and crank gear, almost an 1/8 of an inch.
Cam gear to Injection pump gear:
Crank Gear to Injection pump gear:
Crank gear to cam gear is perfect:
So my questions are:
A: Is the injection pump sup-post to be slightly inset?
B: Is there a bushing that is suppost to go between the injection pump gear and the housing?
C: Judging by the slight gash in the far left of the cast aluminum housing (which must have happened when someone swapped this motor) could the injection end of the case be slightly bent towards the motors and be causing this misalignment? (I checked the rear injection pump support bracket to see if there was any signs of movement and there wasn't)
Thanks ahead for your input!
