Tips for changing rear first gen Tundra shocks - hard earned
slowtwitch
After bailing on a front 5100 install job, and having the shop do it, I had what was left of my man mojo destroyed by an absolutely epic rear shock change out. I was expecting two bolts and two nuts perpendicular to the shock shaft. Instead, I found the upper mount is vertical in orientation like the fronts. No big deal. Pull out the ratcheting box end set, grab the flats on top of the shock shaft... hmm kinda tight quarters... ok there it goes, the nut is free. Ooops... the top of the shaft with the flats just sheared off! Epic. Here's some tips.
- Drop some penetrating oil on the nuts (or on any threaded part of the truck you will be working on) days in advance.
- If you shear the flats off the top of the shock, cut off the hard rubber shaft boot (your up ******T creek if it's metal), and clamp the shock shaft with two pairs of big vice grips as hard as you can. One won't do it as the shaft is hard chromed. I oriented the vg's so they would stop against the frame when I started turning the nut. I also undid the lower shock mount so I could move the shock around a bit. Even with a box end ratchet it was very slow and difficult going. I had to re-tighten the vg's a few times b/c the shaft wanted to spin. The access to the top shock nut just stinks. Also, I found it much faster to lay under the truck and put one hand up to hold the box end ratchet while turning the dual vg's.. more room.
If that hadn't worked, I don't know what plan b would have been. Trying to get a sawsall to the top of the shock would have been a low odds affair. Welding a lever onto the chromed shaft may work, but I really wanted to avoid that with it's possible safety ramifications. Grind flats onto the shaft? Ugh. Cut of the shaft, and get an old box end and drill/tap holes for 3 or 4 large set bolts to hold the shaft? Phew.
st
I just did both the 5100s and rear shocks on a friend of mines 2wd Tundra and it was one of the easiest lifts I have ever done. Way easier than this 4runner I did with the X-suspension crap!
Twitch, sorry you had so much trouble with the fronts, mine have never been that bothersome. I've done the fronts 5 times now on two different trucks and the last time I did the fronts in under 2 hours including aftermath cleanup.
The rear shocks are another story, my fat hands couldn't hardly turn a wrench and the vise grips kept slipping off the chrome shaft. It was a long and arduous process for sure. I'm really contemplating the next rear shocks will be double eye types and install a permanent adapter at the top so I never have to worry about that process again....
I had to cut off both rear shocks on my FJ due to the same situation. The nuts would not give a bit. Plus, they leave you about an 1/2 inch of clearance to get tools on the nut. Bad design all around. It took a week for the burnt rubber smell to leave the garage.
Would it have been easier to loosen the bolts holding the bed down and then lift the bed up a few inches? Or remove the bed altogether? Fuel filler seems like the only real difficult thing to undo and redo.
Lifting the bed isn't easier in my book, but I was for sure mumbling to myself how easy it would be if the bed were off.
What would be trick is a removable cap/plug in the bed right over that nut allowing access.
Glad to hear I'm not the only one in the universe that's had a tough time doing rear shocks
The big take home for me really is hit the project with some penetrant a few days before.
st
Fj89
