tire question
jgolden
I found 2 companies that make: 285/75r17 = about 34"X11.4. I'm in the market for a 100 series LC. I bet these would look great.
MoGas
Central Scrutinizer
If you are building a 100, contact John Shotts, ShottsCruisers here on the board. He has a very well built 100 that runs 35s and you could learn alot about what works and what doesn't to build a 100 right.
Dave
MoGas
Central Scrutinizer
Here is his buildup thread. He's a good guy, a little out there at times, but a good guy none the less. Fiercely loyal to Toyotas would be an understatement.
gearguywb
I have known a couple of guys that ran 305's and both ended up going back to 295 or 285's. The 305 is wider but slightly shorter than the 295/285 series.
There is a lot of talk about 35's on a 100...a lot of it comes from Schott. Slee also has some very specific opinions. There is a lot of good info on
1h8mud.com
ginericLC
That would be a nice tire, unfortunately there are no 17" rims readily available for the 100 series. All of the aftermarket is concentrated on the Tundra which is 18" on up. And Toyota jumped the 17" size and went from 16s to 18s.
I'm running 315/75/16 MTRs on my 100. I'm going to go to a 285/75/16 next time. Hopefully, a Toyo Open Country MT, as that is my favorite all around tire. Awesome off road and fairly quiet on road. I just don't wheel my 100 hard enough to justify rolling around that much extra rubber all the time. It takes fuel to make that rubber roll!
spressomon
That is the key: Don't go to a larger tire than you need for the terrain you are driving. Start small and see how you do. If I didn't need 35" (OK need is a dubious word...however I ran 285R75 16" MT/Rs for over a year and found I was hanging up more than I wanted...35" solved this but it wasn't cheap!) I would have stayed at 33" with 4.56 or 4.88's (that's a whole 'nother thread worth of rhetoric right there :yikes: ).
Personally I like no wider than 285 width. Since going to 285R75 18"...so far about 7,500 miles worth of varied terrain surfaces...I won't be going back to 315 width. It is better in all respects particularly on a 100!
Other than balance issues the GY MT/R is an incredible tire. Compared to Toyo AT/MT it is alot lighter; tough sidewall and casing; tread will last 40K; priced competitively. But the balance issues I had with all my MT/R's finally did them in for me.
rusty_tlc
So far I am very happy with the 285/75-R16 Toyo MTR's we have on the 100. They are only slightly larger than stock so you don't notice much change in road performance, I wouldn't go larger with out re-gearing. They are also loud, but for the places we go I really wanted the heavier sidewall. I have a history of sidewall punctures.
sleeoffroad
Actually 17" was an optional size somwhere along the line for the 100. Not common, but can be found.
ginericLC
iStan814
