bajajoaquin
I'm looking at new tires for my F350, and I've noticed that larger tires may have a lower load range, but an equal or higher rated weight capacity.
For example, my stock size is 265/75 R 16 load range E, capacity 3415 lbs. I'm looking at 285/75 R 16 load range E, with a capacity of 3550 lbs. Then the 295/75 R 16 load range D has 3415 lbs.
The main difference is that the 265 and 285 Es are rated at 80 PSI and the 295 D is rated at 60 PSI.
I put in this same question to the folks at the Tire Rack but I'll put it here, too:
What's the correlation between load range and weight rating?
