TJ Fog Light Upgrade
SAR Jeepster
I like the housing on the TJ Fog Lights it is easy to adjust for elevation and protects the lens better than some of the after market Hella Model 500 Series of lights. The light output seemed to be a little disappointing to me so I opted to change out the highly fluted fog lens for the Hella Model 500 Driving Light lens. This was a much brighter and more useful light for my needs for Overland Travel. The next improvement was to covert from Halogen to HID bulbs this made a huge difference in the light output. The Driving Lens has the HID bulb installed.
picture.php
List of Materials Used:
1. Fog lights from a 2006 TJ
2. Hella Model 500 Driving Lights (HLA-005750952 from Summit Racing)
3. Raptor Brand 35W H3 6000K HID Kit (HIDRAPTORH3-6000K from DDM Tuning)
I first unplugged and removed the 13mm nut under the bumper to take off the TJ fog light. With the light face down on the work bench I removed the 3 #20 Torx head screws. This allows the lens to be removed, pay attention to the lens orientation and gently pry the lens from the retaining ring. The lens from the Hella Model 500 Driving Lights is much easer to remove there is a single Phillips screw close to the mounting bolt. If you are only changing the lens just unplug the wires and leave the bulbs in place. If doing the HID conversion remove the bulb from the lens you are going to use (keeping from touching the bulb with your hands, the oils from you skin will cause the bulb to fail prematurely). Install the driving lens in to the TJ housing orientating it to the same direction as the one you removed. The HID bulb is much longer than the Halogen bulb it looked like the end was touching the back of the lens, so I trimmed a washer to put between the bulb and the reflector.
picture.php
Before replacing the light housing back a 1” hole needs to be drilled to allow for the HID wiring. I drilled mine in the center to put the grommet right behind the back of the bulb to give more room for the bulb length.
picture.php
I found a space behind the lights to mount the ballast and remounted the lights.
picture.php
The elevation is adjusted with a 4mm socket from the front just below the lens.
If you change to Driving Lenses I would recommend using the wiring harness that came with the lenses to allow you use them with your high beams. The HID conversion will not fit the fog lens there is a deflector in the way of the space for the HID bulb.
I am heading to the Black Rock Desert this weekend and hope to get some pictures of them in use. :smiley_drive:
SAR Jeepster
HID Test
I made a trip to Black Rock Desert this last weekend and made the playa crossing at about 9:30pm to give HID conversions a good test. They worked Awesome :wings: longer distance and very bright white light much better than the Halogen. I put a camp chair 200 feet away to give the camera some thing to focus on.
Headlights 55W H4 4000K Halogen
picture.php
Driving Lights 34W H3 6000K HID
picture.php
78Bronco
How much did that setup run you $? Was the camera set in manual mode?
Looks nice from here. Does the super white light fatigue the eyes at all?
SWbySWesty
Fauxverland Extraodinaire
nice, I just did a HID upgrade to my headlights on my XJ. Made a world of difference! I'm definitely not afraid to run trails at night
SAR Jeepster
I had the TJ lights left over from another project: no cost for the housings, about $100.00 w/shipping for the lenses from Summit Racing and $50.00 w/shipping from DDM Tuning. The camera was on auto. I have access to an Extech Light Meter and plan to set it up this weekend and measure actual candle power of all the lights. I also have fog lights from a 2007 JK to test with Halogen verse HID.
So far the for the 30 minuets drive in the desert I didn't notice or even think about eye fatigue.
SAR Jeepster
Lux measurement
Lux measurement of the lights I used on my Jeep. The fog and driving light measurements were for a single light. The Headlights were a pair of lights. All lights include 6 HID TJ w/Driving Lens, 2 HID JK Fog and 2 H4 Halogen Headlights on High.
picture.php
Lux is measured at one point so I moved the meter around to find the best reading. The HID lights covered a much larger area with a larger sweet spot.
Goldenbora
