jhill15
Hey everyone, i'm new to this whole trailer thing so forgive me for sounding like a total newb. I want to build a camping trailer but im not sure if I should build off the utility trailer that I have now or try to find a military trailer or even a newer utility trailer thats already half way there "larger axle, tires, metal floor etc..." also this isn't really gonna be an extreme offroad trailer just camping trips and light offroading.
Heres what im working with.
4x8
900 pound axle
8" tires...I think, they are pretty small.
Plywood floor "needs replaced anyway"
2x4 sides "also need replaced"
1st
Would be a larger axle. There are many on the internet for pretty cheap. But im not sure what to get as far as weight and what hub bolt, tire size, so I can just bolt it right to the mounting points that already exist. I want to go as large of a tire that I can. Possibly 14 inch but i'm also not sure if there is an axle that will fit the 4ft width with 14 inch tires.
2nd
I'm thinking about just re-doing the floor with more plywood as it would be the cheapest route...however I want this thing to be able to keep dry and not have to replace it in another 5 years. So should I just go with metal?
If so where do I locate and what would be the cheapest metal to use?
3rd
Would be the sides. I most definitely want to have metal sides and frame it with metal. So later on I can add a rtt.
4th
A lid. I found a leer hardshell tonneau cover on c.l. for super cheap and its hard not go and snag it up right now, but i'd like to get some opinions first. My plan would be to modify it to fit the trailer add some long struts, some heavy duty cross bars on top for my canoe. The tonneau cover is 4.5 ft x 6.5 ft. So it wont be long enough to cover the entire length of the trailer. Which leads me too...
5th
Rear gate. Bringing the sidewalls of the trailer back to 6.5 ft to match the length of the tonneau cover and adding a swing gate would give me a small platform on the end of trailer. This could be used for extra storage that doesnt require being dry.
At this point i'm kinda stuck between doing this or finding a trailer that doesn't require that much work.
Thanks for any advice, help, knowledge, and suggestions in advance!
4x8
900 pound axle
1st
2nd
3rd
4th
5th
