To swivel or not?
Fallon 40
Just got our cable on the winch drum and was thinking I should put a swivel hook on the end. Do I need one or will a regular hook be fine?
Thanks
Ken
michaelgroves
I like the idea of a swivel, but it's another point of failure, and a potentially nasty one. On balance, I'd opt for not using one. (But someone may come up with a good reason why a swivel is essential, in which case I'll change my mind!)
Antichrist
For wire rope the hardware you use on the end really should be matched to the rope. For instance, using a swivel on some rotation resistant rope can reduce the rope's strength 30% or more.
I'd check with your rope supplier to make sure they are properly matched.
For synthetic, I have no idea if it matters or not.
Jonny Adventures
