TOI's XJ "The Brave Little Toaster"
TOI
Web Adventurer
Right, finally after a few years of rocking a 2wd comanche. Then cutting that truck in half and building a doved truggy and left over parts and never wheeling it. I am finally back into an XJ, which as you will see in this build thread, is a lot of work for what will ultimately be a stock jeep.
enter "the brave little toaster", "warpig", "the beater", or "#racejeep" depending on who you talk to and who may have been a previous owner.
This jeep was owned by a few friends before I rescued it from becoming a parts jeep for other people. unfortunately I don't have many pictures of it sitting on the uniframe with only a front axle and no suspension in it. But I will save ya'll the boring bit. picked it up from my buddy with all the parts to put it together along with some cash for my truggy. Slapped it together with some ZJ axles, worn out suspension, and some old E rated 31's and was surprised that it actually moved. And then came the most interesting bit. Less than a week after putting it together and working out little problems like shorts in the wiring and alignment issues. I loaded it to the brim with house hold goods, hooked up a Uhaul that was way too big for what we needed and loaded that all the way up with stuff and moved across country. In a jeep that three weeks prior everyone thought was going to end up as a scrap.
The jeep pulled nicely for not having any swaybars, and other than some minor non break down faults. Tcase started leaking, had to remove the front driveshaft because of vibes, and the floor catching fire from the muffler being jammed up against it. All went well, and my Fiancee dubbed the jeep the Brave Little Toaster. because its a box and it got toasty inside after 10 hours of highway speeds.
She approves of the jeep, and with it surviving a 14 hour cannonball from Colorado to Texas the long way round. I figure it is about time to make a nice XJ for once. So with all the exposition out of the way, here we are at present day.
My jeep:
91 xj base
ax15
sye'd 231
ZJ lp30 3.73
ZJ d35 3.73
rusty's 3" coils up front
3" AAL and added main leaf in the rear
rancho rs9000 all around
ZJ v8 steering
some adjustable factory style track bar
19# injectors
31" falken load range E tires
modified power steering pump
poly motor mounts
cut fenders
50" light bar
-Ian
TOI
Web Adventurer
and for those curious, here is some of my old MJ
92 unicorn
ax15
231
hp30 locked 4.88s
d44 locked 4.88s
108" WB
XJ rear skins
XJ 3" leafs
short arms
DOM steering
37" mtrs
custom aft tube chassis
TOI
Web Adventurer
Everyone loves that MJ. Kind of wish I still had it some days, but then the wifey and I plus our two border collies hop in the XJ and actually fit. haha
As for the XJ, I'm not 100% sure what I want to do. I want to keep it nice. So I'm thinking either stock coils and leaves with spacers and shackle relocators, or OME if I can justify the cost. Either way I'm probably going to lower it an inch or so. Would like to be about 1.5-2". Find some uncut front fenders, and weld tabs or something to attach rear flares again. Find a Hp30/8.25 in 3.55, lock them and big joint shafts. 235/75 or 30" all terrains. Bumpers front and rear, sliders, skids, and a roof rack. Basically keep it small, nimble, and a comfy daily driver.
TOI
Web Adventurer
Went out to the hill where my fiancee and I ended our first date 5 years go. Looks like the road getting to it was not maintained since, got to do a little wheeling on public roads.
TOI
Web Adventurer
I may have bought way more axle than I will ever need for my jeep, or I started the vague OBS chevy that I want to build. Either way I now have a HP44/60 combo to trip over.
eflores
i kinda miss #racejeep
we should have finished that one
i found your thread looking for pics of truggy on google so i can sell it
and then i saw my tool box lol
iStan814
