Tommy Camper S4 Australian made flatbed camper
Piercecustoms79
This is a 2020 aluminum Tommy Camper S4 model. I had it built and shipped from Australia July of 2020. It came with an Australian made Aluminum flatbed (5ft.X 6ft.) that it was made to mount on. The flatbed can be fitted to any mid or full-size truck. It has four compartments that can be mounted underneath on either side of the rear tire. The camper is a spring loaded pop up. It goes up manually. It has extra thick canvas tent material and zippered windows. The bed is a little smaller than a queen with a 3 inch mattress. Its equipped with a full kitchen on the driver side. A stand up fridge/freezer with a pantry. It has a fold out counter and sink. It currently has one 20 gal. water tank plumbed to the sink and an additional spicket on the back. I have another twin 20 gal. water tank that can be installed if needed. It has a Redarc Manager 30 system installed with two 150w solar panels on the roof and a 100 amp hr. Battle born Lithium battery. Theres an on/off switch to cut power. A fuse panel to add more auxiliary systems and charging ports. Inside theres standing room to change clothes, hangout and use a porta potty if desired. Theres one large drawer I used for clothing and a bench to sit on and change. You can access under bench storage from inside. On the outside is a 270 23Zero Ptarmigan awning The camper has a four bolt system that attaches it to the flatbed and can be removed from the flatbed if desired. It comes with four jacks that lift the camper and you can drive out from under it. The camper is approx. 1200 lbs. dry. The flatbed weighs approx. 200 lbs. I had it mounted on a moded 2007 Tacoma trd sport. Fully loaded I weighed in at 4,200 lbs. and I carried a lot of stuff.
I'm locate in Denver Colorado. I'm selling both the camper and the flatbed together for $35,000. It cost me $45k fully loaded with everything it has and shipping. I'm willing to put my labor into your build and help you get it mounted for your vehicle. I'm a fabricator and could at least get you started if you come to me with a truck with no bed on it. Feel free to call or text; Nate Pierce @ 719-494-3384.
lkretvix
