Can someone tell me torque specs for a 95 montero sr camshaft bearing caps (12mm and 10mm bolts). I am unable to locate them in fsm. search online and found specs for 6g72 to be 14 ft-lbs for the 12mms and 8 ft-lbs for the 10mms.
Torque specs for the camshaft caps are unknown according to Tech/Faq in 4x4wire. Imma post in 4x4wire regarding the specs but would appreciate if you could get get me those numbers SOFpirate.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
