Located in North Oaks, MN 55127 - Will be traveling to Upper Michigan and Colorado in the near future. Delivery along those routes possible. Happy to assist with freight as well. I have a nice pallet available (in pics) for shipping.
I am selling a 4400 lb Lippert torsion axle off a 2020 travel trailer camper. The axle only has a few hundred miles on them. I am selling due to an axle upgrade after some significant modifications to the camper and I needed a heavier axle. No issues with the axle. Again this came off a NEW 2020 camper.
The axle brackets are located 59-1/4" apart, which is the inside frame measurement. The outside of the axle bracket would be at 63-1/4" apart, which is the outdide frame measurement, so it sits nicely on 2" frame rails. Hub face to hub face is 79-1/2" apart. Hub face is the point where the studs come out of the drum & the wheel contacts the drum.
The torsion arm angle is 22.5 degrees down.
The axle has easy lube spindles and electric brakes.
This would be a great axle for anyone building a utility trailer, overlander RV, or teardrop camper.
