MummifiedCircuitry
I'll try to keep this as simple as possible, basically my torsion bars aren't adjusting evenly. I had turned them up months ago, and ended up turning the Left bolt MUCH higher than the Right just to get it close to even. The Right side measurement front the ground to the edge of the fender flare was 36.75" with about 1.75" of adjustment bolt sticking above the nut on the t-bar. Just to get me Left side up to 36" from ground to fender edge, I had to turn up the bolt to where about 3.5" of thread was above the nut on the t-bar. I didn't feel comfortable turning it up more, so I just left it even though it wasn't totally level. Recently, I wanted to get an alignment, so I decided to turn the Left side down to where it matches the 1.75" of the right side. Now it's measuring 36.25" on the Right (which I didn't touch), and 35.25" on the Left side. Any ideas what I should do here? I cancelled my alignment appointment because I don't want to waste $75 before I figure this out. To be clear, I'm driving the vehicle between every adjustment so it settles and I already trimmed my bump stops months ago. My understanding is that the drivers side should be set 1/4" higher than the right to compensate for driver weight too, I don't see how I can even get that close. Any advice would be appreciated.
