torsion crank question. but not a how to.
T
twistedsmily
Guest
I was wondering. How much is everyone cranking their bars.
I just did 5 turns on mine (2wd) and its just almost level with the back. Was thinking about 2 or 3 more but not sure.
T
twistedsmily
Guest
Id like a more level ride. But not sure how much lift per turn is achieved.
SoCalMonty
A: However many turns it takes. As the bars wear, 4 turns on mine might produce a different result than 4 turns on yours. Measure each side every few turns, and make sure you don't run out of threads on the adjusters (if you do, you'll have to re-index the bars. Takes about 15 mins).
T
twistedsmily
Guest
Oh ok. So more trial and error thing. Ok. Guess ill give it a few more turns and see what comes of it.
SoCalMonty
It probably is, but make sure the front tires are in the air (jacked up). And you might end up resting on the bump stops; check for that once you lower the truck again.
T
twistedsmily
Guest
round up going with 8 turns ,
You talkin about the droop stops. On the upper controll arms. Still have little less then an inch from them might trim them down a bit.
