Towing with 03 f150 supercrew 5.4
UHAULER
I'm thinking about getting a carson rebel toyhauler they are 7'x14' and weigh about 3,200# empty, closer to 3,500-4,000 ready to go. I had one about 5 years ago and pulled it with an 02 f350 7.3 diesel no problem. Right now this is the only truck I have. Just trying to decide if it will pull it for a while until I can upgrade the truck. Ideally would like to find an 02-05 f250 v10 with manual trans.
Current truck
Old setup
Marine
I used to tow around 3000 with my f150. But had weight distribution hitch and sway bars. Over kill probably but better to be safe
Buliwyf
Viking with a Hammer
The 5.4 was in the SD's as well. 9000# is no big deal for it.
If the truck's stable and level. Add spring as needed.
GoinBoardin
My buddy used to pull a heavy steel 4 place open snowmobile trailer with a truck just like that, it did the job fine. Probably 1500 lb empty trailer (total guess, could have been much more, sure felt like it), plus ~2400 lb of sleds, and a tall spray shield on the front. Usually ran in 3rd gear, until a headwind kicked up or climbing a pass, then it was 2nd gear. He was the only one with a crew cab so we were always taking his truck.
dhuss
