Toyo Open Country M/T 295/70/17 on 7.5" wide rim?
NCprepper
It is time for me to replace my tires so I purchased a set of 2004 Dodge Ram 2500 17 x 7.5 steel wheels.
I would like to run the Toyo Open Country M/T 295/70/17 tires but I am concerned that the 7.5" wide wheel may be too narrow?
Is anyone running the Toyo Open Country M/T 295/70/17 on a 7.5" wide wheel?
Would it be ok to air these down for camping on the beach?
My truck is a 1999 Dodge Ram 2500 CTD 4x4 so I like the Max Load rating of 3970lbs for these tires.
I am currently running a 315/75/16 which is too tall for my taste and 3.55 gears.
The Toyo Open Country M/T 295/70/17 tires are listed as having a 33.5" diameter.
Is there another tire with comparable Max Load rating but slightly smaller diameter?
Mad_Texan
From Toyo's web site a 7.5 is an approved width...
Size Product Code Approved Rim Widths-Weight-Tread/32"-Diameter-Width-Static Loaded Radius-Max Load(1)-Max.Press-Revs/Mile-Tread Const-Sidewall Const
LT295/70R17 360360--7.5-8.5-10.0-------72.8-------19---------33.5-----12--------------15.6--------------------3970----------80----------619---------3P+2S+2N--------3P
DoMiNiC1
I run a MT 285/70/17 on hummer wheels, 17x8 and they are plenty wide. I think you would be fine with a 17.5, you could get some cheep CL hummer wheels..
This is what treadwright suggested for 285's (they don't sell 295's) so you would be on the narrow side but I think it would be fine.
285/70R17 (E)
Tread Depth:
17/32”
Meas. Rim Width:
8.5”
Tread Width:
9”
Rim Width Range:
7.5-9”
Max Load:
3,750 lbs
Outer Diameter:
33”
Max PSI:
80 psi
Section Width:
11.5”
This is close to the size you will be running . This is not a woman, could a half inch make that much difference?:coffee:
Height – 33″, Width – 11.5, Rim 7.5-9
RocKrawler
Supporting Sponsor
No problems, guy with lifted duallys run 35x12.5 tires on 6" wide rims routinely so your narrower tire will fit on that wider rim no issues
Regcabguy
Oil eater.
I ran my 285-75-17 Toyo AT's at 60-65 psi for 36K on stock rims because of the constant camper weight. I experienced premature center wear. Currently,I'm running 55# in my 285-75-17 Toyo MT's. Initially,I was concerned that the lower payload capacity(3195#) compared to my prior Toyo AT's would be a concern,but no problem. The 3195# is plenty. A 285 would be a better match for a 7.5" rim.
Airing down will not be an issue.
The new Toyo ATII will be my next tire as Toyo has not released a 285 M-55 in a 17" so far.
bloodyWEST
FWIW i'm running Nitto terra grapplers (same manufacture/same tire as Toyo AT) 285/75 17 on H2 wheels 17x8.5 IIRC
i stepped down from 35/12.5 16.5 to the Nittos and i'm very happy. Nittos calls them a 34x11.5(the stickers that were on the new tires)
The sidewalls feel very firm. i have only had them about 5k miles but they look brand new. I love the taller/narrower tire.
travelall74
