Toyo red light issue
UK4X4
red light on dash glowing..
OK maybe a basic Q
The handbrake light is full on
Disengage the hand brake and the light stays glowing.
Normally this means the alternator is history...
But the battery is full
The voltages are good both engine running and off
The switch on the handbrake is good.
Battery brand new
terminals brand new
What does this little glowing light mean ?...low amperage ?
In my older years it meant turn off everything not required and run for home before the battery dies
UK4X4
Toyota LC RJ 77 is the truck with a 22R engine...GCC version
mmm OK I'll check the brakes tommorow
DaveInDenver
Middle Income Semi-Redneck
Yup, Kurt is probably right on. This is the problem 99.95% of the time, low brake fluid. It's supposed to indicate it's time to replace to service them (assuming there is no leak). My truck when the charging system is weak has a dummy light, IIRC it actually says CHARGE. But I also have the voltage gauge in my instrument cluster.
UK4X4
This is my first toyo for about 20 years...my last was a mark 1 celica
funnily enough with the same engine...
On old brit cars it was always the warning for alternator...yep have seperate voltage indicator
will rumage around tommorow
Thanks for the info- I was about to splurge on a new alternator and regulator..
so much for my basic truck knowledge....duh
iStan814
