Toyota factory wheels on a trailer
jwilson2598
Question for you guys who have run Toyota wheels on your trailers. I have a Manley ORV that is a M416 clone. I just recently swapped my Jeep out for a new Tacoma TRD OffRoad and want to change the wheels to match. It look like the center is big enough to fit over the trailer hub (3500 lb Dexter Axle with brakes). So my question is:
1. Am I correct the wheel will fit over the hub
2. Will the wheel/tire clear the tub on it, or do I still need spacers?
I'm hoping to ditch the spacers I was using on the JK wheels and get 6 lug brake drums to fit the wheels, but if I still need spacers I might just keep my current brakes and get new spacers. Thanks for the help.
Atchcraft
I'm not sure I'm tracking correctly. But, the hub center on the trailer drum is pretty small and will clear no problem. If your hub has a 6x5.5 lug pattern, then the first step is good to go. As for the rubbing, totally depends on what the wheel back space is. Time to break out a tape measure. I just converted my trailer to run the same wheel as my T4R and even if you need to swap out hubs, it's pretty cheap and easy. Hope this helps.
