Toyota split rims
Grease Cruiser
I have several sets of Toyota 5 lug split rims for sale. These are the 5 on 150 mm pattern and will fit all 100 series, newer Tundra, Sequoia, and 70 series Cruisers 1999+ I do not have any that fit the older 6 lug pattern.
$10 for each wheel
$10 for each tube/liner combo
I will sell the tube/liner separate from the rim.
These rims can be made into non-split rims if desired. I can cut the centers out and send to a wheel manufacture to be made into 16x7, 16x8, or ? Average cost is about $130 +/- to make into standard rims. These make for a cool non-USA look.
You can see more info here:
http://forum.ih8mud.com/tires-wheels/497474-oem-100-series-split-rims.html#post7522877
The tire in the picture is not included. These are the wheels only.
Located in SLC, UT 84106. These wheels are heavy to ship but I will do so on your dime. Approx. weight is 40lbs for each wheel
View attachment 95689.
Loras BR
Do you still have them?
Is it possible to change the pattern to fit the 80 Series?
Are they good to fit 295 tires?
Would you do it and send them to Brazil?
Thanks.
