cascadediesel
We are selling our setup as our family is growing and things are becoming tight in our little camper!
The Truck:
2005 Tacoma TRD Sport 4x4 Double Cab Long Bed
-The TRD sport package has a mechanical limited slip differential, and also a larger sway bar than the TRD off road, which is why I sought out this truck for a FWC, so it handles great. (also sport seats)
-Four Wheel Camper Bed Brackets
-Firestone Air Bags
-Full service records since new, starting with the window sticker (we are third owner)
-In the last year I have had a lot of work done to keep it mechanically perfect, to match my meticulous upkeep including-- brakes (calipers, discs, pads, drums, shoes, wheel cylinders, brake booster), wheel bearings, East Coast Gear Supply clamshell bushing (don't buy a Tacoma unless this has been done!), belts, alignment, prob more, have receipts for all done professionally.
-187,5xx miles
-Custom waterproof seat covers, can't remember brand,
-Rubber TRD mats
-Tailgate included, of course
-This truck starts, drives and stops like new. It is exceptional for the mileage, as you can see from the pictures.
-All wiring for camper uses marine grade hardware, with redundancy on the breakers for solenoid
-Tow Package with transmission cooler
-Avg an honest 16.8 MPG on most trips
-Clear title, absolutely zero accidents, one small dent behind driver's rear wheel
The Camper:
2003 Four Wheel Camper Eagle
-New vinyl floor, floor pack inspected at that time, good to go.
-New rear door
-Rear bike fork mounts for carrying bikes vertically. They are out of the way completely, so you can always get into the camper without have to mess with them.
-Sink with manual pump, two burner stove and ice box, fresh water tank
-Heater is an Olympian Wave 3 Safety Heater, definitely the most efficient heater available, and it cooks if desired.
-Northstar AGM battery, brand new. Meter doesn't show a drop after 3 days of lights and charging devices etc. It was around $300 I think. This setup does not need solar, and you never have to worry about using power.
-Added USB charging ports
-All LED lighting
-Modular table
-Marine epoxy reapplied on bottom for extra protection
-All stainless hardware
-Added diamond plate for extra protection
-All new trim when switched over to stainless hardware
-Vinyl/canvas in good shape, a few pinholes in the corner were seam gripped
-Switches/breakers installed so you can turn on/off all lights and power while standing outside at the back door, you'll get why if you use it, very handy.
-Roof vent
-Four Wheel Camper factory luggage rack
The combo works awesome together, very easy and capable.
$24,500 OBO
Thanks,
Mike - Located in Bellingham WA
(925)330-8775
The Truck:
-Firestone Air Bags
-187,5xx miles
-Rubber TRD mats
The Camper:
-New rear door
-All LED lighting
-Modular table
-Roof vent
$24,500 OBO
Thanks,
(925)330-8775
