TOYOTA TACOMA
AAM
(39k miles)
Manual Transmission
4 Door
Short Bed
V6
4x4
Sunroof
SORRY HAVING TROUBLE WITH UPLOADING PICTURES. WORKING TO RESOLVE. THANKS
LOW KM'S. Truck was never used as a daily driver, no one has even ever sat in the rear seats. Used mainly for camping. No expense was spared. Has everything you need for traveling, camping and overland type adventures including waterproof storage, fridge/freezer, awning (with enclosure and floor), 12v and 120v power, lighting etc etc etc. Located in PEI,CA. Truck can be delivered or shipped. NO RUST, frame and inside body panels permalc coated and oil sprayed, accessories (bumper, rock sliders, brackets etc) all hot dipped galvanized and Line X'd. There are a lot of accessories included (traction boards, rotopax, ipad, axe, shovel, waterproof storage boxes etc etc etc)… If you have any questions feel free to ask. $45,000 usd/ open to offers. Financing available. Accessories can be added or removed to adjust price to the right buyer.
See below for upgrade details (+more)
UPGRADES...
SUSPENSION
Dobinsons HD Front Springs
Dobinsons HD Rear Springs (w/ Greaseable Bushings)
Dobinsons Front and Rear Shocks
SPC Greaseable Upper Control Arms
BAMF HD Shackle Hangers and Greaseable Shackles
DRIVETRAIN
OV Tune (hardware to edit included)
ARB Case Breathers x2 w/ Manifold...
Front Differential
Rear Differential
Transfer Case
Transmission
In-House Fabrication Stainless Steel Snorkel
Method 17” Black Hybrid Bead Lock Rims
275 70 17 (33”) MT Tires
Full Size Matching Spare Tire and Rim
Rear Tire Carrier
Gorilla Splined Extended Thread Black Lug nuts
ECGS Bushing Upgrade
Exhaust Reroute
Upgraded Engine Splash Guards
EZ Oil Drain Valve w/ Filter Drain tool Included
2WD Low
Clutch Accumulator
Reinforced Cam Tabs
ARMOUR
Paint Matched LineX...
Hood
Grill Bezel
Front Fender
A-Pillars
Roof
Rocker Panels
BAMF Hybrid Front Bumper...
Full Center Hoop
Bash Plates
Reinforcement Brackets
Hot dip Galvanized and Premium LineX Coating
BAMF Bolt-On Rock Sliders...
DOM Tubing
RCI Front Skid Plate (w/ Oil Filter Access)
RCI Transmission Skid Plate
RCI Transfer Case Skid Plate (Exhaust Reroute)
Stainless Steel Mesh Radiator Protection
LIGHTING
Baja Designs 30” Amber Light Bar (Front Bumper)
Baja Designs Squadron Amber (6 Lights on Front Bumper)
Baja Designs S2 Ditch Lights w/ Rago Fab Stainless Steel Brackets
LED Interior Lights
LED Reverse Lights
H9 Low and High Beam Headlights
ELECTRICAL
BlueSea Battery Voltage Gauge w/ Switch
NorthStar 100amp/hr AGM Battery
Upgraded Battery Mount and Tie Down
Battery Terminals
Noco Onboard Battery Charger
Noco 120v Receptacle (Front Bumper Mounted)
Switch Pros 9100
Stainless Steel Mount
Uniden CB Radio...
Removable Antenna
Rugged Ridge X-Clamp Mount w/Flexible Spring
Midland GMRS Radio...
Low Profile Antenna
Electrical Accessories Installed With High Quality Components...
Marine Grade Tinned Wire
Insulated Heat Shrink Connections
Double Wall Heat Shrink
BlueSea High Quality Marine Grade Buss Bars, Fuse Blocks, Solenoids
All Electrical Runs Fuse or Breaker Protected
All Electrical Runs Protected with High Quality Wire Mesh Sheathing, Loom and Grommets
Heat Shrink Labelling
RECOVERY
Warn Zeon 10K...
BlueSea Marine Rated High Amperage ML Solenoid w/ Cab Mounted Switch
BlueSea Marine Rated Fuse Protection
Wireless Remote Control
Synthetic Rope
Factor 55 Hawse Fairlead
Factor 55 Flat Link Expert Shackle
ARB Twin Compressor...
Cab Mount Switch Control
Bluesea Fused
Expedition Essentials Bedside Storage Mount
Rear Bumper Flush Mount Quick Connect Output
25’ Hose Inc.
Blow Wand Inc.
OTHER ACESSORIES AND UPGRADES
FrontRunner Awning
Full Room Kit w/ Floor
Prinsu Roof Rack...
Black Stainless Steel Hardware
Wind Deflector with Wind Noise Edging
FrontRunner Rotopax Mount
FrontRunner Traction Board Mount
3.5 Gal RotoPax Inc.
MaxTrax Traction Boards (Black) Inc.
Waterproof Cases x2 w/ Strap downs and Stainless Steel Eyelets
OEM Tacoma Black Badging
Center Console Cover
OEM TRD Pro Shifter
Full Front and Rear Seat Covers
Engel Fridge...
Slide Lok Mount (Remove Fridge with a push of a button)
Mini Anderson Electrical Plug (Flush Mount)
Engel Insulated Cover
Leer Mid Height Cap...
Cap and Truck Bed Sealed Against Dust and Water Intrusion
LED Lighting
Interior Carpet
Sliding Windows
Upgraded HD Screens
Bed Stiffeners w/ LineX Coating
Modular Rear Carpeted Platform (Aluminum Construction)
Warrior Quick Latch Shovel Mount (Shovel included)
Warrior Quick Latch Axe Mount (Axe included)
OEM Bed Mat
Tailgate Panel Insert
TRD Pro Grill
Rear Seat Underside Lockable Gun Safe/Storage
DMM Dash Mount
Fire Extinguisher...
Underside Front Seat Mount (Extinguisher included)
WeatherTech Front and Rear Floor Mats
WeatherTech Window Guards
Blue Ridge Front Head Rest Storage (Driver and Passenger)
GreyMan Tactical Front Driver and Passenger Door Molle Panels
Blue Ridge Storage Bags (Driver and Passenger)
Bushwacker Fender Flares
Frame and Underside of Body Panels Coated with Permalac (NO RUST)
RokBlokz Mud Flaps
Hood Struts
MAINTENANCE
Truck has been religiously maintained...
Engine Oil and Filter...
Changed Every 3,500-5,000kms
Mobil1 Full Synthetic
Air Filter...
Changed with Engine Oil and Filter
Transmission, Front and Rear Differential Fluids...
Changed Every 10,000kms
Engine Coolant...
Mobil1
Changed Every 25,000kms
Brake Fluid...
Mobil1
Oil Spray...
Every Spring and Fall
Grease Points...
Weekly
Hi sorry I’ll update the ad…
2017
Truck is located in PEI, Canada
FYI. I can help getting anyone in touch with import/export professional if buyer is outside Canada. Financing available and delivery/shipping possible. Thanks
tbnd88
