Track Bar/pitman arm
gwayms
Ok so im not totally clear. I just put a 4.5 rough country lift on my XJ and need an adjustable track bar. Im about to order it and want to know. Do I have to need a pitman arm?
The Adam Blaster
Some people say you do, others say you don't.
I just did a 4.5 Rubicon Express on my '98 XJ, and I needed one. There are guys on NAXJA that still don't believe me, but I took it to 3 different shops, and they all said that I needed it, and the geometry would not have been correct wit the stock pitman.
I trust the shops over the internet. ;)
Especially when one of the shops was a specialty 4x4 place, and another specialized in front end work.
You can finish the lift and check the steering when you're done, and if it's not working and you're getting bump steer, you can order the larger drop pitman at that point.
I think my larger DP was around 100 bucks, or thereabouts...
gwayms
track bar
yeah the shop i took mine said the same thing. I figured they knew what they were talking about, they have always been pretty straight forward with me.
Maximus Ram
I got my drop pitman off of e-bay for a good price at the time(about a year or so ago)
Also, what adj trackbar are you looking at ? I had a rustys on mine and kept snapping the TRE's. Ended up getting a RE HD double shear with the drop bracket. A bit more than I wanted to spend, but after all is said and done..I should have done it right the first time...
here's a few with a quick check
http://shop.ebay.com/i.html?_nkw=ch...arm&_osacat=0&bkBtn=&_trksid=p3286.m270.l1313
The Adam Blaster
I haven't yet, but I probably should have gone to heavier steering components.
I am running MT tires, 33x12.5R15's, so there will be a lot of stress on those steering components when I'm bombing around on the trails.
(I'm not very gentle to the XJ when I'm 'wheelin.) ;)
wjeeper
I have seen rigs get a fair bit of bump steer when adding just a drop pitman arm or just a drop trackbar bracket. You want your trackbar and draglink to be roughly parallel. The less parallel they are the greater the bump steer you will get.
My $.02
gwayms
track bar
i just order rough country adj track bar and pitman arm. should be here in a few days.
wjeeper
Cheap upgrade is to run the linkage off of a ZJ with a v8. The tubing is thicker. And at local self serve yards here in Utah they are $15-20. Plus you can keep your stock linkage for a trail spare.
TOTJ
What is comes down to is you want them to stay in line or I should say at the same angle.
As example if you have a 4" lift w/ out a new track bar or droped pitman arm the y will both still be equal. If you put on a pitman arm and a trac bar but the track bar is in the stock location the you have two difrent angles.
One angle from the trac bar and now less angle from the drag link.
On the other hand if you install a droped pitman arm and a track bar that has a drop down like the one from Rubicon Express it keeps the two in line.
You want to keep the drag link angle and the track bar angle as close as you can or you may get bump steer.
The only other reson to run a droped pitman arm is if your steering is binding.
during droop.
alosix
yeah, this is probably what I'll do, too. All my TRE's are blown.
I'd LOVE to get the Currie Correctlync setup, but $350.00 is a lotta money. :Wow1:
I just can't see spending that much on a TJ/XJ/ZJ front end that doesn't get rid of the inverted Y setup.
after many years of driving a TJ with an ORO uturn on it, I have a hard time driving stock Jeeps :)
Jason
The Currie kit is the best and strongest bolt on system out there. As to your question, if you are now running a dropped trackbar bracket, then you need a dropped pitman to restore the relationship of the trackbar and draglink. If you haven't installed a dropped trackbar bracket, then run with your stock pitman.
30-284
^^^ Listen to the man.
Donn
Toolman
go to the junk yard and take one off a grand cherokee ($10)... it's the same as Rubicon Express ($60) and a lot cheaper.... I have worn out 3 of the RE in 6 months... I lowered my jeep 1" since the last one so we'll see if it lasts.
anything over 3" lift you need drop to get the geometry right
BTW the way currie recommends the stock pitman arm with there set up and their TRE are junk... replaced Drag link a few times as well.. I'm going to a high steer as soon as I get the $$$$$ and hoping to sell my Currie set up .. To me the bars are great but they need to work on their customer service and TRE.
Really lost respect for that company since my last conversation with "Tech-Support" couldn't answer simple question about degree angles and tried to make me feel inferior... however the customer wins.... I was very close to buying the anti-rock sway bar until that conversation.. I will never give Currie another penny of my money.
Currie is also great at displacing the blame... so in other words. THEY DON'T WARRANTY ANYTHING !!!!!!!! F CURRIE
Clemtiger84
