I am building a trailer and can't seem to find an axle with manual parking brakes. I am interested in something like the M416 set up. Any suggestions??
Thanks
I got mine pre set-up with my new Dexter Axle from RedNecktrailersupplies.com. They will build them custom and direct ship. I haven't hooked up the actual handle/cable mechanism yet, but the brakes themselves work from the manual lever. Hopefully this winter. I could have used them a few times while camping instead of having to find large rocks/chocks.
Not sure if you mis-understood... But to clarify, not all of them do. If you look on the dexter web-site, there are about 15-20 different options for brakes, and I think only one of them, the 10", 3500# variety has the option to ALSO get the E-brake feature. Actually, there might be a couple other ways to get the e-brake, but none that would probably interest you.
Mendenhall's got a hydraulic brake actuator that's pretty serviceable. Croft Trailer sells them, as I'm sure does E-Trailer. Not sure what your budget is, but Croft's version is just a bit north of $500.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
