Trailer Battery
T-Rey1
Hello all,
I am wanting to install a deep cycle marine battery, inverter and charger / maintainer in my trailer to run some lights and a fan or heater for the tent depending on the weather while camping. My trailer has a 4 way plug now and my 2012 Tacoma has the 7 pin so I use a 7-4 adapter. The 7 pin on the truck has a pin that says it is + power and all the other connections. Can the + power pin be used to charge the battery while driving?
elmo_4_vt
Sure can... Pretty simple hook-up. Just basically connect the + pin to the battery Positive terminal (preferably through a fuse), and the ground pin on the connector to the trailer ground and negative terminal. Any other questions, just ask.
Don
T-Rey1
Thanks don,
Any recommendation on fuse size. I purchased a size 31 deep cycle battery. Is the power from the 7-pin charging power from the alternator?
Martyn
It's typical to run 10 gauge wire back to the 7 pin. Use a breaker with a manual reset placed as close to the main battery as possible. Auto breakers can trip due to the heat under the hood. You should be able to find a medium range 30 amp breaker. Alternatively you could use a 25 - 30 amp fuse.
T-Rey1
Finally got my battery set up installed and working. Took it the the Lonestar Jamboree over the weekend. Worked great, but could always be better. Changed out my trailer 4 pin to a 7 pin and ran the power wire to the battery from the 7 pin. I need to get a shot of the battery installed
