computeruser
With the weather warming up,I am hoping to finally complete my camping/canoe carrier trailer project from last year. But I need some input on what material to use for the decking and sides.
I was thinking about plywood at first (either standard stuff that would be painted heavily or marine grade), but I've been entertaining the idea of sheet aluminum instead, since it would weigh less and require less upkeep. The trailer will be stored outdoors at least part of the year.
Assuming I go with aluminum, how thick of a sheet of aluminum would I need for a solid decking surface? I'm assuming that .063 would be fine for the sides, but would it be rigid enough for the floor?
Below is the bare chassis. The main rails are 30" apart, and the cross beams are about 18" apart. So the spans aren't very large at all, which might make the thinner stuff work OK. What do y'all think?
This is the partially completed body that would need to be skinned.
